Hi, I'm addressing BSP-7948 issue so I can inform you of the cause and fix in an effort to assist others. Please feel free to close this immediately.
Fix:
JVM wrapper settings changes fix problem
Approach
wrapper.ping.timeout=900 wrapper.ping.interval=30
References
Problem:
Agent builds stop and results lost after missing heartbeat. for months this appears to be server problem. Re-evaluate
Situation:
2013-02-12 11:12:22,785 INFO ActiveMQ Session Task DefaultErrorHandler
Recording error: Agent General Purpose Windows X64 (vmwbuild-03) went offline while building TRUNK-QUICKCOMPILEWINDOWS-2876.
The build results will not be saved. : TRUNK-QUICKCOMPILEWINDOWS
Agent
ERROR | wrapper | 2013/02/12 11:08:54 | JVM appears hung: Timed out waiting for signal from JVM.
ERROR | wrapper | 2013/02/12 11:08:55 | JVM did not exit on request, terminated
STATUS | wrapper | 2013/02/12 11:09:10 | Launching a JVM...
ERROR | wrapper | 2013/02/12 11:09:34 | Startup failed: Timed out waiting for a signal from the JVM.
ERROR | wrapper | 2013/02/12 11:09:34 | JVM did not exit on request, terminated
STATUS | wrapper | 2013/02/12 11:09:39 | Launching a JVM...
ERROR | wrapper | 2013/02/12 11:10:08 | Startup failed: Timed out waiting for a signal from the JVM.
ERROR | wrapper | 2013/02/12 11:10:08 | JVM did not exit on request, terminated
STATUS | wrapper | 2013/02/12 11:10:13 | Launching a JVM...
ERROR | wrapper | 2013/02/12 11:10:42 | Startup failed: Timed out waiting for a signal from the JVM.
ERROR | wrapper | 2013/02/12 11:10:42 | JVM did not exit on request, terminated
STATUS | wrapper | 2013/02/12 11:10:47 | Launching a JVM...
ERROR | wrapper | 2013/02/12 11:11:16 | Startup failed: Timed out waiting for a signal from the JVM.
ERROR | wrapper | 2013/02/12 11:11:16 | JVM did not exit on request, terminated
STATUS | wrapper | 2013/02/12 11:11:21 | Launching a JVM...
INFO | jvm 105 | 2013/02/12 11:11:31 | Wrapper (Version 3.2.3) http://wrapper.tanukisoftware.org
INFO | jvm 105 | 2013/02/12 11:11:31 | Copyright 1999-2006 Tanuki Software, Inc. All Rights Reserved.
INFO | jvm 105 | 2013/02/12 11:11:32 | WARNING - Unable to load the Wrapper's native library 'wrapper.dll'.
INFO | jvm 105 | 2013/02/12 11:11:32 | The file is located on the path at the following location but
INFO | jvm 105 | 2013/02/12 11:11:32 | could not be loaded:
INFO | jvm 105 | 2013/02/12 11:11:32 | d: bamboo-agent-home bin .. lib wrapper.dll
INFO | jvm 105 | 2013/02/12 11:11:32 | Please verify that the file is readable by the current user
INFO | jvm 105 | 2013/02/12 11:11:32 | and that the file has not been corrupted in any way.
INFO | jvm 105 | 2013/02/12 11:11:32 | One common cause of this problem is running a 32-bit version
INFO | jvm 105 | 2013/02/12 11:11:32 | of the Wrapper with a 64-bit version of Java, or vica versa.
INFO | jvm 105 | 2013/02/12 11:11:32 | This is a 64-bit JVM.
INFO | jvm 105 | 2013/02/12 11:11:32 | Reported cause:
INFO | jvm 105 | 2013/02/12 11:11:32 | D: bamboo-agent-home lib wrapper.dll: Can't find dependent libraries
INFO | jvm 105 | 2013/02/12 11:11:32 | System signals will not be handled correctly.
INFO | jvm 105 | 2013/02/12 11:11:41 | Agent bootstrap using baseUrl: http://vmbamboo-01:8085/bamb
{code}
Heartbeat problems can happen when the agent restarts the local JVM when it fails to respond. We can avoid these by relaxing the schedule for checking the JVM.
References
