×Hello everyone,
At our company we use Jira, Bitbucket and Bamboo to make our daily work a lot easier. Our repository is organized in the git-flow schema:
develop-branch = Application code for testing (aka Release Candidate)
master-branch = Application code running live
feature-branches = new components based on actual dev-Branch merged back after finish
hotfix-branches = new hotfixes based on master-branch merged into develop and master after finish
Our versioning system works like the following:
Now I'm trying to integrate our structure into Bamboo. I created a plan triggered by changes into the dev-branch containing two stages:
1: Develop - Build develop -> deploy after finish
2: (manual) Production - Build master -> deploy after finish
That works fine with feature Branches. How do I handle hotfix branches? Do I need an additional plan or is it possible to create a single plan to cover the whole process?
Chris
I have automated and implemented a similar structure along with release branches.
It would be helpful if you can provide the type of application you are building (maven, angular/node) and also some more details on how you are building the feature branches.
From what I see, if you're using JIRA to create hotfix and pull requests to manually merge hotfix to master and develop after testing is complete, you don't really need additional plan.
+1
