How to Create a Project from within Java Code in JIRA?
tushar_chopade
October 24, 2018
I want  to create a project ,plan and job from java code in to bamboo .I download the jar file of bamboo .Also tell me hot to do connection from java code to bamboo using username and password .
Reply ASAP.
Chris Berry
November 1, 2018
Hi Tushar,
It sounds like Bamboo Specs is what you are looking for. Specs will allow you to create a Bamboo project, Plan and Job through either a YAML definition or Java code. You can find details of Bamboo specs here.. Bamboo specs.
thanks
Chris
Atlassian support - Bamboo
