How to auto-merge Stash develop branch in feature (plan) branches in Bamboo
Pascal
February 10, 2015
I'm trying to setup automatic merging of the development branch into a feature branch in Bamboo as described here: https://confluence.atlassian.com/display/BAMBOO/Using+plan+branches#Usingplanbranches-Usingautomaticmerging
However, I cannot seem to set this up, since our Git repository is Stash and Bamboo tells me (on the Branches tab of the build plan configuration): "Merging is disabled for this plan branch as the default repository 'Develop' is of type 'Stash', which does not support automatic merging.". This seems ultimately weird, as underlying is simply Git and merging seems to be available for Git repositories.
So my question is: can I really not achieve automatic merging with Stash or am I just overlooking something?
rsperafico
May 21, 2015
Hello Pascal,
I am sorry for the delay on getting back to you.
Based on the screenshots you have provided, it seems Bamboo is using JGit as capability instead of Git. Please, go to "Bamboo administration >> Build resources >> Server capabilities" and make sure you have added Git as a Capability as per following:
If you find this answer useful, I would kindly ask you to accept it so the same will be visible to others who might be facing the same issue you have inquired.
Thank you for your understanding.
Rafael P. Sperafico
Atlassian Support
Pascal
February 12, 2015
Hi Rafael,
That is "develop". Here a screenshot of that page and one of the branching model:
Pascal
rsperafico
February 12, 2015
Hello Pascal,
Thank you for all the information.
Could you let us know what is the Default Branch associated with your repository "Applications / IBE" in Stash, please? In can find this information under "Repository >> Settings >> Repository details >> Default branch"
Rafael P. Sperafico
Atlassian Support
Pascal
February 12, 2015
We're using version 5.7.2. Here are some screen shots of our configuration:
Thanks for your help!
Krystian Brazulewicz
February 12, 2015
Which Bamboo version do you use? Can you please post the screenshot of your plan repository configuration?
