Here is my project structure:
pom.xml
/dir1
/pom.xml
/dir1_1
/pom.xml
/dir2
/pom.xml
/dir2_1
/pom.xml
/dir2_2
/pom.xml
It would be nice to use a modular plan in Bamboo. The parent poms are both aggregate and inheritable.
I would like to have the following stages in a plan:
Where I would have multiple plans, each compiling, testing and deploying individual projects from the overall project; i.e. dir2_2 under dir2 (dir being a substitute for a project name). In order to build dir2_2, I need to have the upper and core pom projects available.
Is this possible?
Overall structure:
* Plan - Build All
* * Stage 1 - Build Proj 1
* * Stage 2 - Build Proj 2
Stage structure:
Stage N
Job 1
Task a = Source Checkout task top-level upper parent POM to sub-dir .\
Task b = Source checkout task core POM to sub-dir .\dirN
Task c = Source checkout task project to sub-dir .\dirN\dirN_m
Task d = Call 'mvn deploy' inside .\dir\.dirN_m
That's it.
"mvn deploy" will of course depend on tests passing, which of course will depend on a compile. Though it will be much easier to make dirN_m a self-contained project that doesn't require the ..\pom.xml and ..\..\pom.xml. You can release those POMs as artifacts to your Maven repo and list them as dependencies in dirN_m's pom.
N.B. Multiple checkout tasks is only possible in Bamboo 3.3. Another way to do that is to setup a "shell" project in your source repo that has the structure needed. You can accomplish that with svn:externals, git/hg sub-repos, P4 client specs, ClearCase viewspecs, etc...
Rene,
If I were to click the Wallboard view would I just see a single pass/fail for the entire Plan? Our preference is to be able to break out the test pass/fail per artifact.
Does an easy way exist for this?
Thank you,
Shane
