How to do proxy settings for specific job in bamboo plan
Amit Goel
November 9, 2017
Dear Friends,
I am trying to execute the soapUI test suite on bamboo using maven test command, however in order to execute this , I need to set specific proxy for the plan,
Request you to kindly assist in setting the proxy server as I am facing unknown host error.
Amit
robhit
November 13, 2017
I am not aware of soapUI but will try to help you here with the proxy configurations.
can you share your proxy configurations?
and which proxy server you are using?
