×Hi
We use Bamboo On Demand to build and deploy our projects.
We also use a local Jenkins to run Selenium Webdriver tests on a deployed system.
Now, i want to be able to automate the flow:
Questions:
Thanks !
Was there a solution for this issue to call Jenkins test job from Bamboo??
Thank you,
Can you setup the Selenium web driver tests within Bamboo itself using a command line interface?
My test must run on Win / Mac OS. Last time i tried to run the tests from Bamboo itself it failed because it was impossible to use Bamboo's agent on my machines.
