How to run Java Project using Bamboo?
Gaurav Dighe September 10, 2018
I have a java project created in eclipse with test cases. I want to run that test cases using bamboo, but without maven, ant or grails. All my libraries are all ready added to classpath. Please assist.
Anonymous Coward
Simon says:
First run your Java application from a command line, outside Eclipse. Verify that it works correctly.
Then Create a Script task in one of your Bamboo plans and run the same command that you run on the command line from the script task.
Simon out.
