How to specify libs, building with Ant?
Deleted user January 8, 2014
I've been trying to build with Ant and I need to specify some libs to it, so, I tried with ANT_OPTS="-lib C:\..." but it doesn't recognize the -lib option.
Thanks in advance,
Gretchen
January 12, 2014
If you're building java try putting -Dlib=C:\... on the target line
