I have a deployment project which will use same ANT file which is used in the connected build plan,how do i call the same
Debajyoti Pal
January 20, 2015
Krystian Brazulewicz
January 21, 2015
In your Job define a shared artifact that will match your ANT file, then those artifacts will be available in deployment using ArtifactDownloader task
Debajyoti Pal
January 20, 2015
In Deployment environment,I want to use the same instance/version of the ANT file which is used in Build plan .
regards
Deb
