  • Community
  • Products
  • Bamboo
  • Questions
  • I have separate projects in Bamboo Project A and Project B. If Project A launches a build through the agent on Server 1 is Project B prevented from launching a build on server 1?
William Kouri
February 22, 2017
Christian Glockner
February 22, 2017
Hi William,
Tasks in Bamboo are executed by agents, and an agent will always execute only one task at a time. If you only have a single agent (local, remote, or elastic), in the situation you've described, if Project A runs a build, Project B cannot build and the other build is finished.
Christian
Premier Support Engineer
Atlassian
