I there a way to set an execution order for Build Plans?
Andrea Colarieti
November 28, 2017
Hi there,
to explain my "problem" further:
I have different builds of the same software for different Clients (depending from the same Repo).
We usally let all branches be built so that they can be singularly tested before integration.
At the moment my plan names follow a simple schema ( AppName_Client1, AppName_Client2, AppName_Client3).
The moment i push some changes all build plans get triggered
and the server seems to have an alphabetically sorted queue, meaning the client I'd like to see the buildresults for is always at the end the queue.
I'd like to know if there already is some possibilty to change the working order or alternatively, could you link me to a feature request site?
Any kind help will be appreciated.
Thank you in advance,
Andrea Colarieti Tosti
robhit
November 29, 2017
Hi Andrea,
Plans do not have the working order but there is a feature which allows us to create plan dependencies (parent plan - child plan relation) using which we could create some order.
Thanks!
