We are moving from a local bamboo jira instalation to the atlassian onDemand but looks like ondemand doesnot have support for a important feature for us, the jira bamboo integration mainly to version management.
In our instalation we have Applications link configured and we can see and select between the jira versions in bamboo.
Once that Applications links are not available in the ondemand version, what would be the best approach to integrate jira - bamboo, mainly for releasemanagement, artifact management.
Thanks in advance.
Bamboo version used on OnDemand does not have all of the JIRA integration features available in the newer, Download version. Among others, release management is missing.
You should be able to use the integration features once OnDemand upgrades to Bamboo 4.x version. We are currently working on upgrading it.
Thank for your answer.
Do you have idea when this upgrade will happens? I 've checked on ondemand confluence but i haven't found anything about this upgrade.
An official date is not yet announced. We are currently working on it - it's a tricky update (for us) and it will take some time before it's available.
The upgraded bamboo on demand has really good new features however i haven't found a way to configure link applications or a way to do the release[1] management work. Is it possible in the new bamboo release ?
Thank you in advance.
Gustavo, this feature should be available in 1 to 2 weeks when we deploy an update to the JIRA and Bamboo integration.
