Is it possible to define variable at job level and artifact name
Emmanuel Boudrant February 26, 2013
I see i can define variables on the plan, I would like to configure variables at the job level. Is it possible to define variable at job level ? I've seen nothing on the documentation so far.
I need that to build a kind of job template and set some variables depending what it is going build (here the name of the Xcode project)
I have the same question for the artifact name where I would extract the IPA as ${bamboo.XcodeProjectName}.ipa
Adam Myatt
March 11, 2013
There are a variety of Variable-related plugin https://marketplace.atlassian.com/search?q=bamboo+variable but none seem directly targeted at what you need. The closest is probably the Inject Bamboo Variables plugin https://marketplace.atlassian.com/plugins/com.atlassian.bamboo.plugins.bamboo-variable-inject-plugin You could use it to define grab defined key=value props from your repo in each Job where you want the variables to be.
