Is there a manual to understand how to install Bamboo Data Center on GKE at least with the following requirements:
I have search info on Atlassian Document site, but I haven't found something specific.
I'll really aprecciate if you can help me with a terraform file or a similar template
There is also a guide on Running Bamboo Data Center on a Kubernetes cluster meanwhile (essentially the supported part of the developer focused and unsupported Deployment Automation for Atlassian DC on K8s solution you found already, i.e. just the Helm charts w/o Terraform).
I've found the following information that has gave me a clear ideo from where to start with a Bamboo Data Center Installation on K8
I hope the link could help somebody else: https://community.developer.atlassian.com/t/terraform-ga-available-for-bamboo-dc-apps-performance-testing/55522
