JDK capabilities with spaces in name as bamboo variable
Andrei Markov September 23, 2013
If a plan needs to use a specific JDK in a script task, how can I specify it? What works is generic one "java17=${bamboo.capability.system.jdk.JDK}". Say we'd like to use 1.7.025. So far tried:
java17=${bamboo.capability.system.jdk.JDK 1.7.0_25}
java17=${bamboo.capability.system.jdk.JDK\ 1.7.0_25}
java17=${"bamboo.capability.system.jdk.JDK 1.7.0_25"}
None worked :(
EddieW
September 23, 2013
We recommend that you do not use capability labels with space characters, if you wish to use them as variables. A possible solution for space characters is to format them with '${}' symbols, however, this does not work in all cases.
https://confluence.atlassian.com/display/BAMBOO/Bamboo+variables#Bamboovariables-Specifyingcapabilitiesasvariables
JDKs apparently are autodiscovered and so labels are auto-created. I am hesitant to make changes to all of them (currently about 15 different JDKs in our bamboo). But I found this this works just fine:
java17="${bamboo.capability.system.jdk.JDK 1.7.0_25}"
Since this format is in line with your answer I am going to accept it.
JoeA August 11, 2014
I think it would be really nice if the JDK dropdown was available on script tasks. Since Gradle isn't supported out of the box, the only way to run a Gradle build it by using the script task, not having a JDK dropdown available just makes choosing your own JDK much more complex than it should be.
David Shapiro
Are these variables something I can use inline in the build plan task?  I tried to use java17="${bamboo.capability.system.jdk.JDK 1.7.0_25}" in the inline script, but it throws an invalid substitution error.
Jean-Claude Passy October 10, 2016
See my answer in the same thread: "
${bamboo.capability.system.jdk.JDK 1.8}" works for me, as well as the environment variable "$bamboo_capability_system_jdk_JDK_1_8"
Jean-Claude Passy May 31, 2016
Oups, apparently I have to remove the "+" from
${bamboo.capability.system.jdk.JDK+1.8}
which yields
The corresponding environment variable also works (that is printed in the logs) for the sh scripts
I am hitting the same issue, JDK 1.8, the capability key looks like this:
system.jdk.JDK+1.8
and I do not know how to get rid from the "+"
