Making a Bamboo Script execute using /bin/bash
dustingooding
I need to run a script using /bin/bash instead of /bin/sh, but I'm not seeing a way to do that.
In the logs, I see that /bin/sh is used to execute my script. In my script, I print out the $SHELL variable, and nothing shows up on the screen. So, I assume it's /bin/sh that's being used to run the script... but I can't confirm it. Putting #!/bin/bash at the top of my script doesn't help.
The reason I need to use /bin/bash is that a process I need to start requires a set of environment variables to be set using a an inline function (e.g., source `rosstack find orocos_toolchain`/env.sh) but I don't believe /bin/sh supports that, or the source call.
Colin Goudie
January 10, 2012
You should be able to add a new builder from the builders admin menu {URL}/admin/agent/viewBuilders.action
e.g. on our Bamboo instance our Bash builder uses /bin/bash
JulioAmerica May 12, 2017
Good Day
I currently have this problem and not sure where to find this builders admin menu.  Our system actually runs on bin\ksh but bin\bash will do for this instance as we just need a script to run
Could you possibly send a screenshot.
I am using Bamboo:
Bamboo version information
Version5.11.1.1
Build number51117
Build date 4/28/16
Please help
John Gill
In Bamboo 6.1 you can add a script command and have it run in sh or bash or ps.
Not sure if this helps since you're on 5.11
The solution above was for Bamboo Cloud.
Like 唐晓健 likes this
16 votes
Jonathan Loesch
June 19, 2014
The accepted answer works if you are running a "command" task from bamboo (i.e. execute a script file).
If you are trying to run a "script" task, which is just running an inline script, you can try putting this snippet at the top to force it to execute in bash. It's a hack, but it worked for me:
#!/bin/bash
if [ "$(ps -p "$$" -o comm=)" != "bash" ]; then
    # Taken from http://unix-linux.questionfor.info/q_unix-linux-programming_85038.html
    bash "$0" "$@"
    exit "$?"
fi
samfulton July 16, 2014
Champion! worked for me
Jerry Henley
February 17, 2015
Very nice! Thanks!
Kevin Ross
Woohoo! Thanks. You would expect this to be simpler with bamboo....Atlassian, are you listening?
frank-weindel January 29, 2016
No. Atlassian has no time for small fundamental details
This really sucks when you have to bootstrap it in 30 different script tasks.
ABA
I was able to achieve this by adding below to my script itself
#!/bin/bash
Tried this but did not work for me
Like # people like this
Aaron Yang
January 18, 2021
Doesn't work, my Bamboo version is 6.9.2.
Jurgen Schober
if you use git/sh use
#!C:\PROGRA~1\Git\bin\sh.exe
in your shebang line (first line in inline script)
It's an absolute path. You can run any interpreter this way (cygwin/mingw). Please note: no spaces in the file name!
Cintia Calvo April 13, 2017
In Bamboo < 5.13, on the agents, if the non-login shell is bash, it should work adding the she-bang on script tasks.
You can achieve that by linking /bin/sh to /bin/bash, instead of /bin/dash or whatever.
From 5.13, it should work regardless of your non-login shell.
https://confluence.atlassian.com/bamboo/bamboo-5-13-release-notes-829057609.html
How can I achieve this without upgrading.
Currently running:
Version5.11.1.1
Build number51117
Build date4/28/16
