Need Deployment Automation support for Mulesoft using Bamboo
Sharan Busetty
July 7, 2017
I'm working on automating the Builds and deployments for Mulesoft using Bamboo. Currently need help on automating the deployments of Mulesoft Zip files to CloudHub. We are using maven pom.xml to do our builds. When we use the same pom.xml to do the deployments (i.e., mvn deploy command) as well, It is recompiling and zipping the artifacts again. So how can I avoid the recompiliation and Zipping of artifacts again when the deploy goal was called. Also please let me know if there are any other working ways to deploy the Mulesoft code to CloudHub using Bamboo,. Thank you!
Elza Carciu
November 12, 2017
i just want to bump this question too, as it 's something we're very interested in too.
(i'll put up another more specific qu re our requirements and current (mis-)understandings -- we're trying to use a `mule:deploy` step to get a project into cloudhub, but our build artefact is a deployment archive without a pom.xml...)
