Dear Team,
I am new to Atlassian. Currenly I have installed Bamboo and Jira trial version and integrated both the application so that I can report bug directly from the Bamboo.
I am facing issue while watching 'Build Summary Report' as that is not as per requirement.
I need below Reporting as mentioned under https://www.atlassian.com/software/bamboo>> TEST >> CI ON THE BRANCH PREVENT DRIFT QUARANTINE TESTING AT SCALE
Please suggest what odon I need to install into bamboo to see desired 'Build Summary Result'
Tapashwani
You will only see the Quarantine option with a failed test. You must have plan admin permissions to quarantine (I think - doc was fuzzy on this).
Hi Gretchen,
Thank you for your response.
Currently I am getting below report in Bamboo
But I am looking for report with Quarantine option, mentioned below
Please suggest if there any plugin or tricks to acheive Report with 'Quarantine' option enabled.
Tapashwani
The build summary "report" described in that link is displayed at the end of every build. (failed or successful). It accurately lists all jira issues associated with the build assuming you 1. use jira, 2. identify the jira ticket associated with the code checkin in your checkin comments.
