Need to integrate Tosca with bamboo.any help is appriciated
sumit bhagat
November 21, 2017
I need to integrate Tosca in bamboo for ci/cd .I am not able to understand how can I integrate those two.please help.
Ashrith
July 4, 2018
@sumit bhagat Did you try this plugin?
robhit
November 21, 2017
Hi Sumit,
If setting up the add-on with Bamboo then below steps:
  1. Log into your Bamboo instance as an admin.
  2. Click the admin dropdown and choose Atlassian Marketplace.The Manage add-ons screen loads.
  3. Click Find new add-ons from the left-hand side of the page.
  4. Locate Tosca for Bamboo via search.The appropriate app version appears in the search results.
  5. Click Try free to begin a new trial or Buy now to purchase a license for Tosca for Bamboo.You're prompted to log into MyAtlassian. Tosca for Bamboo begins to download.
  6. Enter your information and click Generate license when redirected to MyAtlassian.
  7. Click Apply license.If you're using an older version of UPM, you can copy and paste the license into your Bamboo instance.
    Reference - https://marketplace.atlassian.com/plugins/com.mdb.plugins.toscaforbamboo/server/installation
But, I doubt that you are looking for something else. Let me know if that's the case.
