×In Bamboo build plan one can define dependencies - child build plans to be triggered.
It is also possible to manually define branches of a build plan.
Is it possible to define dependencies for a branch build plan, different from their respective master build plan dependencies?
Have you found an answer to this question yet? I don't want to run dependencies on our master branch as our master branch is currently setup to run a different set of maven command that will cause an artefact release.
