I want to have an integration branch as my base branch. feature/dev.
I then want to create a Bamboo plan branch which will run a set of basic build checks after pulling in any changes on feature/dev. If successful, then merge the changes into the plan branch.
Flow:
I create this basic build plan and linked it to my repo with feature/dev as branch. Set up my stages and jobs. Selected create plan branches and enabled merging with branch updater.
This seems to work great
Now I want another plan which is downstream of these branch integrator builds. It would be the gatekeeper and run more extensive tests and if successful merge the changes back into the integration branch feature/dev for each run of a plan branch...
How to do this? I cloned the Branch integrator plan and tried to modify it to be a gatekeeper in branch merging but was unsuccessful. It is very confusing to be honest.
Any help would be appreciated!
/Tim
could you share the regex we need to use for feature branches? i somehow cant get this working both merging and plan branch creation.
Sorry for the late answer. But I got it working. Thanks
How exactly is your plan configured and what is not working.
It's hard to help without more details.
I assume you have read this one already: https://confluence.atlassian.com/display/BAMBOO/Using+plan+branches#Usingplanbranches-Gatekeeper
