Hello all,
I'm trying to link my Perforce repo to Bamboo. Bamboo is throwing an error. Has anyone experienced anything similar?
Here is the error info:
Version: 6.1.0
Build: 60103
Build Date: 18 Jul 2017
Stack Trace:
java.lang.IllegalArgumentException: Unknown cipher data id 0 at com.google.common.base.Preconditions.checkArgument(Preconditions.java:122) at com.atlassian.bamboo.crypto.instance.InstanceSecretStorage.getCipherData(InstanceSecretStorage.java:92) at com.atlassian.bamboo.crypto.instance.InstanceSecretStorage.getKeyAndIv(InstanceSecretStorage.java:84) at com.atlassian.bamboo.crypto.instance.InstanceCipherProvider.getKeyAndIv(InstanceCipherProvider.java:60) at com.atlassian.bamboo.crypto.instance.InstanceCipherProvider.getCipher(InstanceCipherProvider.java:46)
The stack trace is much longer, but I can't post it all.
As a note - this problem is happening after I have imported a backed-up database. Seems to possibly be a permisisons issue within the C:\ drive, but I have also tried putting the Bamboo Home directory in other places with no luck.
