Problem with Bamboo Gadgets in JIRA
Vincent Kopa _Ovyka_
I've followed the full guide up to https://confluence.atlassian.com/display/ATLAS/Dragons+Stage+9+-+Bamboo+Gadgets+and+JIRA+Victory
But now when I add the Bamboo gadgets in JIRA they do not get displayed (only the title of the boxes is displayed in the gadgets, their contents are completely blank.
I've looked at the logs and found many of these :
2012-12-09 19:51:31,319 http-bio-8080-exec-23 WARN admin 1191x361x1 10hf15i 82.230.94.46,127.0.0.1 /secure/Dashboard.jspa gadgets.embedded.internal.GadgetUrlBuilder GadgetUrlBuilder: could not parse spec at http://xxxxx:8085/bamboo/rest/gadgets/1.0/g/com.atlassian.bamboo.gadgets/status/planStatus.xml
2012-12-09 19:51:31,319 http-bio-8080-exec-23 WARN admin 1191x361x1 10hf15i 82.230.94.46,127.0.0.1 /secure/Dashboard.jspa gadgets.renderer.internal.GadgetSpecFactoryImpl Error occurred while retrieving gadget spec for http://xxxxx:8085/bamboo/rest/gadgets/1.0/g/com.atlassian.bamboo.gadgets/charts/planSummaryChart.xml
2012-12-09 19:51:31,320 http-bio-8080-exec-23 WARN admin 1191x361x1 10hf15i 82.230.94.46,127.0.0.1 /secure/Dashboard.jspa gadgets.renderer.internal.GadgetSpecFactoryImpl Error occurred while retrieving gadget spec for http://xxxxx:8085/bamboo/rest/gadgets/1.0/g/com.atlassian.bamboo.gadgets/charts/planSummaryChart.xml
2012-12-09 19:51:31,320 http-bio-8080-exec-23 WARN admin 1191x361x1 10hf15i 82.230.94.46,127.0.0.1 /secure/Dashboard.jspa gadgets.embedded.internal.GadgetUrlBuilder GadgetUrlBuilder: could not parse spec at http://xxxxx:8085/bamboo/rest/gadgets/1.0/g/com.atlassian.bamboo.gadgets/charts/planSummaryChart.xml
2012-12-09 19:51:31,320 http-bio-8080-exec-23 WARN admin 1191x361x1 10hf15i 82.230.94.46,127.0.0.1 /secure/Dashboard.jspa gadgets.renderer.internal.GadgetSpecFactoryImpl Error occurred while retrieving gadget spec for http://xxxxx:8085/bamboo/rest/gadgets/1.0/g/com.atlassian.bamboo.gadgets/charts/bambooCharts.xml
I've downloaded the file http://xxxxx:8085/bamboo/rest/gadgets/1.0/g/com.atlassian.bamboo.gadgets/charts/bambooCharts.xml with a wget on the same server, it gets it without a problem and seems well formed...
Can you please help with these please errors ?
Regards
Sultan Maiyaki
December 11, 2012
This issue was investigated and we found out that the root cause is due to the strict security rules on chrome browser whereby it can not render gadgets from foreign applications (Bamboo or confluence) if the security mode is different from JIRA. Therefore if JIRA is https and Bamboo is http, then the gadgets from Bamboo will be blocked. You can relax this security constraint as per the instructions here https://support.google.com/chrome/bin/answer.py?hl=en-GB&answer=1342714
FYI: This does not affect other browsers such as firefox
Tahir Bhat
April 8, 2020
