REST call posting comments with html links problem
Deleted user March 18, 2014
Hi there, We are trying to post comments via REST that link to particular labels, i.e instead of posting a comment that says "The labels on this job are: x y and z" I wanted to post "The labels on this build are x .....etc i.e. embedding links to them, However, even though I post a payload of: <comment> <content>some test ABC or other</content> </comment> I only get the words " or other" in the comment. Am I doing this in the wrong way? Is there a different way of performing links? The curl command I am using to send the content that is in a file called content: cat content | curl -fail --silent --verbose --header 'Content-Type: application/xml' --request POST --data-ascii @ --user-agent 'Hotels.com Shell Library & SCM System' --user xxxxx:xxxxx – http://bamboo.hotels.com/rest/api/latest/result/BOOKING-BAMB-274/comment?os_authType=basic Support Request Sent by: v-jborkowski@expedia.com Priority: 3 --------------------------------------------------------------------------------------- This is the end of an automated request sent using the Support Tools Plugin ---------------------------------------------------------------------------------------
EddieW
March 22, 2014
Are you posting XML?
DId you escape the comment in CDATA?
<,> and other characters used in links are invalid as XML values/attributes.
