Am I able to create a project via REST calls in Bamboo 6.2.2?
James October 30, 2017
I have tried PUT /rest/api/latest/deploy/project
but am getting back: "The plan you selected could not be found."
with a 400 response.
Nothing else appears suitable for project creation.
Am I missing something?
Gonchik Tsymzhitov
Hi!
Could you clarify your question?
What method have you used? (You should use PUT)
More info here https://docs.atlassian.com/bamboo/REST/6.2.2/#d2e927
It will be nice if show your response from server
curl -s -u user:passwd -X PUT -H "Content-type: application/json" "http://bamboo.myinstance.com/rest/api/latest/deploy/project"
Then it will be possible to understand why you have seen error 400.
Gonchik Tsymzhitov
curl -s -u admin:admin -X PUT -d '{"name":"Test deployment 1","planKey":{"key":"PROJ-PLAN-1"},"description":"Project description 1"}' -H "Content-type: application/json" "http://localhost:8085/rest/api/latest/deploy/project"
{"errors":[],"fieldErrors":{"masterPlanKey":["The plan you selected could not be found."]}}
I've also tried omitting the planKey.
{"errors":[],"fieldErrors":{"masterPlanKey":["Please specify a Bamboo plan to pull deployment artifacts from."]}}
Is it not possible to create an empty project, and add plans afterwards?
Przemek Bruski
October 30, 2017
You can use Bamboo Specs to create projects (or anything, really) remotely. https://confluence.atlassian.com/bamboo/bamboo-specs-reference-documentation-894743916.html
James October 31, 2017
Okay, so I can't create projects using the REST API, I need to use Bamboo Specs?
It looks like I can't queue build plans from Bamboo specs. Am I right in thinking I'll need to use the Bamboo specs to define projects, plans and jobs, and then use the REST API to trigger the plans?
Also, I'm curious to know if there are any future plans to add a project creation endpoint to the REST API. It would be very useful if we weren't tied to Java and could do all our automation through REST calls.
