Can I set labels for a build plan using Bamboo Specs in java?
No, it's not supported. How do you use labels? Please describe your scenario
I am using Maven (with Bamboo Specs) to generate Bamboo build plans from an established template. All of these build plans will have the same plan labels that we are using to group them together. It would be nice to be able to configure that as part of the Specs template.
I assume we might be able to use the Bamboo API to handle this instead? I'm just trying to automate this process end to end.
Thank you!
Created feature request to gather interest - https://jira.atlassian.com/browse/BAM-19899 . You can vote on it as Bamboo team takes item into development queue based on votes and watchers
Another easy approch is Bamboo REST API to add label from your script.
