Hello Team,
I'm facing issue at Maven Build Task on Plan set up for Mule Project in bamboo. I have Maven set up in my local properly but i see below error logs when i try to build on bamboo. Maven is set on E: drive on my local and corresponding path is configured in environment variable
Error logs in Build :
simple 18-May-2018 06:58:19 Executing xray actions for the following build: International Monitoring - cs-monitor-p - Default Job #6 (IM-CSMONP-JOB1-6) simple 18-May-2018 06:58:20 Build International Monitoring - cs-monitor-p - Default Job #6 (IM-CSMONP-JOB1-6) started building on agent Bamboo Local 2 simple 18-May-2018 06:58:20 simple 18-May-2018 06:58:20 Build working directory is /efs/bamboo/bamboobin/build-dir/IM-CSMONP-JOB1 simple 18-May-2018 06:58:20 Executing build International Monitoring - cs-monitor-p - Default Job #6 (IM-CSMONP-JOB1-6) simple 18-May-2018 06:58:20 Starting task 'Check out source code' of type 'com.atlassian.bamboo.plugins.vcs:task.vcs.checkout' simple 18-May-2018 06:58:20 Build always requires a clean checkout simple 18-May-2018 06:58:20 Cleaning build directory '/efs/bamboo/bamboobin/build-dir/IM-CSMONP-JOB1' simple 18-May-2018 06:58:21 Updating source code to revision: 48c26c1bd49b90cf20eeaac1b7da083dd438abaa simple 18-May-2018 06:58:21 Fetching 'refs/heads/develop' from 'ssh://git@bitbucket.creditsafe.com/im/cs-monitor-p.git'. simple 18-May-2018 06:58:21 Warning: Permanently added '[127.0.0.1]:37653' (RSA) to the list of known hosts. simple 18-May-2018 06:58:22 Checking out revision 48c26c1bd49b90cf20eeaac1b7da083dd438abaa. simple 18-May-2018 06:58:22 Creating local git repository in '/efs/bamboo/bamboobin/build-dir/IM-CSMONP-JOB1/.git'. simple 18-May-2018 06:58:22 Cloning into '/efs/bamboo/bamboobin/build-dir/IM-CSMONP-JOB1'... simple 18-May-2018 06:58:23 done. simple 18-May-2018 06:58:26 Switched to a new branch 'develop' simple 18-May-2018 06:58:26 Branch develop set up to track remote branch develop from origin. simple 18-May-2018 06:58:26 Updated source code to revision: 48c26c1bd49b90cf20eeaac1b7da083dd438abaa simple 18-May-2018 06:58:26 Finished task 'Check out source code' with result: Success simple 18-May-2018 06:58:26 Running pre-build action: VCS Version Collector simple 18-May-2018 06:58:26 Starting task 'Build Mule Project' of type 'com.atlassian.bamboo.plugins.maven:task.builder.mvn3' command 18-May-2018 06:58:26 Beginning to execute external process for build 'International Monitoring - cs-monitor-p - Default Job #6 (IM-CSMONP-JOB1-6)'\n ... running command line: \n/usr/bin/mvn --batch-mode -Djava.io.tmpdir=/opt/atlassian/atlassian-bamboo-5.15.5/temp/IM-CSMONP-JOB1 mvn clean package\n ... in: /efs/bamboo/bamboobin/build-dir/IM-CSMONP-JOB1\n ... using extra environment variables: \nbamboo_planRepository_1_branch=develop\nbamboo_capability_system_builder_nunit3_NUnit_3_Build=C:\Windows\Microsoft.NET\Framework*64*\v2.0.50727\msbuild.exe\nbamboo_repository_49512449_branch_name=develop\nbamboo_planRepository_1_branchDisplayName=develop\nbamboo_repository_revision_number=48c26c1bd49b90cf20eeaac1b7da083dd438abaa\nM2=%M2_HOME%\bin\nMAVEN2_HOME=/usr\nbamboo_resultsUrl=https://bamboo.creditsafe.com/browse/IM-CSMONP-JOB1-6\nbamboo_planRepository_1_name=cs-monitor-p\nbamboo_build_working_directory=/efs/bamboo/bamboobin/build-dir/IM-CSMONP-JOB1\nbamboo_buildKey=IM-CSMONP-JOB1\nbamboo_repository_49512449_name=cs-monitor-p\nbamboo_shortPlanName=cs-monitor-p\nbamboo_planRepository_name=cs-monitor-p\nbamboo_buildNumber=6\nbamboo_capability_system_jdk_JDK_1_8_0_131=/usr/lib/jvm/java-1.8.0-openjdk-1.8.0.131-2.b11.el7_3.x86_64\nbamboo_shortJobName=Default Job\nbamboo_buildResultsUrl=https://bamboo.creditsafe.com/browse/IM-CSMONP-JOB1-6\nbamboo_capability_system_builder_nunit3_MSBuild_Run=C:\Program Files (x86)\MSBuild\14.0\bin\MSBuild.exe\n-Xmx512m=\nbamboo_planRepository_repositoryUrl=ssh://git@bitbucket.creditsafe.com/im/cs-monitor-p.git\nbamboo_capability_system_jdk_JDK_1_8_0_121__JRE_=/usr/lib/jvm/java-1.8.0-openjdk-1.8.0.121-0.b13.el7_3.x86_64/jre\nbamboo_agentId=22446081\nbamboo_planName=International Monitoring - cs-monitor-p\nbamboo_shortPlanKey=CSMONP\nbamboo_repository_49512449_previous_revision_number=48c26c1bd49b90cf20eeaac1b7da083dd438abaa\nbamboo_shortJobKey=JOB1\nbamboo_repository_49512449_git_branch=develop\nbamboo_planRepository_revision=48c26c1bd49b90cf20eeaac1b7da083dd438abaa\nbamboo_repository_previous_revision_number=48c26c1bd49b90cf20eeaac1b7da083dd438abaa\nbamboo_buildTimeStamp=2018-05-18T06:58:19.762Z\nbamboo_planRepository_previousRevision=48c26c1bd49b90cf20eeaac1b7da083dd438abaa\nbamboo_repository_49512449_revision_number=48c26c1bd49b90cf20eeaac1b7da083dd438abaa\nM2_HOME=/usr\nbamboo_buildResultKey=IM-CSMONP-JOB1-6\nbamboo_repository_git_branch=develop\nbamboo_repository_branch_name=develop\nbamboo_buildPlanName=International Monitoring - cs-monitor-p - Default Job\nbamboo_planRepository_1_revision=48c26c1bd49b90cf20eeaac1b7da083dd438abaa\nbamboo_repository_49512449_git_repositoryUrl=ssh://git@bitbucket.creditsafe.com/im/cs-monitor-p.git\nbamboo_capability_system_jdk_JDK_1_8_0_141=/usr/lib/jvm/java-1.8.0-openjdk-1.8.0.141-1.b16.el7_3.x86_64\nbamboo_repository_name=cs-monitor-p\nJAVA_HOME=/usr/lib/jvm/java-1.8.0-openjdk-1.8.0.111-1.b15.el7_2.x86_64/jre\nbamboo_dependenciesDisabled=false\nbamboo_capability_system_docker_executable=/usr/bin/docker\nMAVEN_OPTS=-Xms256m\nbamboo_planRepository_branch=develop\nbamboo_capability_system_builder_nunit3_msbuild_exe=C:\Windows\Microsoft.NET\Framework*64*\v2.0.50727\nbamboo_agentWorkingDirectory=/efs/bamboo/bamboobin/build-dir\nbamboo_capability_system_git_executable=/bin/git\nbamboo_repository_49512449_git_username=\nbamboo_planRepository_1_previousRevision=48c26c1bd49b90cf20eeaac1b7da083dd438abaa\nbamboo_repository_git_username=\nbamboo_planRepository_branchDisplayName=develop\nbamboo_capability_system_jdk_JDK_1_8_0_151=/usr/lib/jvm/java-1.8.0-openjdk-1.8.0.151-1.b12.el7_4.x86_64\nbamboo_planRepository_1_type=bbserver\nbamboo_planRepository_branchName=develop\nbamboo_capability_system_jdk_JDK_1_8_0_151__JRE_=/usr/lib/jvm/java-1.8.0-openjdk-1.8.0.151-1.b12.el7_4.x86_64/jre\nbamboo_capability_system_jdk_JDK_1_8_0_111__JRE_=/usr/lib/jvm/java-1.8.0-openjdk-1.8.0.111-1.b15.el7_2.x86_64/jre\nbamboo_capability_system_jdk_JDK=/usr/lib/jvm/java-1.8.0-openjdk-1.8.0.111-1.b15.el7_2.x86_64/jre\nbamboo_plan_storageTag=plan-48660481\nbamboo_planRepository_type=bbserver\nbamboo_planRepository_1_username=\nbamboo_ManualBuildTriggerReason_userName=oc-rohity\nbamboo_repository_git_repositoryUrl=ssh://git@bitbucket.creditsafe.com/im/cs-monitor-p.git\nuseMavenReturnCode=false\nbamboo_capability_system_builder_node_Node_js=/usr/bin/node\nbamboo_capability_system_builder_command_AWSCLI=/bin/aws\nbamboo_capability_system_builder_mvn3_Maven_3=/usr\nbamboo_working_directory=/efs/bamboo/bamboobin/build-dir/IM-CSMONP-JOB1\nbamboo_planKey=IM-CSMONP\nbamboo_planRepository_1_repositoryUrl=ssh://git@bitbucket.creditsafe.com/im/cs-monitor-p.git\nbamboo_planRepository_username=\nbamboo_capability_system_jdk_JDK_1_8=/usr/lib/jvm/java-1.8.0-openjdk-1.8.0.111-1.b15.el7_2.x86_64/jre\nbamboo_planRepository_1_branchName=develop\nPATH=/usr/lib/jvm/java-1.8.0-openjdk-1.8.0.111-1.b15.el7_2.x86_64/jre/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin\n error 18-May-2018 06:58:26 /usr/bin/mvn: Failed to set JAVACMD error 18-May-2018 06:58:26 /usr/bin/mvn: Failed to set JAVACMD error 18-May-2018 06:58:26 /usr/bin/mvn: Failed to set JAVACMD error 18-May-2018 06:58:26 /usr/bin/mvn: Failed to set JAVACMD error 18-May-2018 06:58:26 /usr/bin/mvn: Failed to set JAVACMD error 18-May-2018 06:58:26 /usr/bin/mvn: Failed to set JAVACMD
Can someone point out what else needs to be configured or reason for issue and how to resolve ?
This error means that Java Home couldn't be set.
From the build log and screen shot, this Maven task is configured to use the Java path /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.111-1.b15.el7_2.x86_64/jre as JAVA_HOME.
Check if this path /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.111-1.b15.el7_2.x86_64/jre exist in the machine hosting Bamboo.
If it does not exist, edit the JDK 1.8 Capability at Administration > Build Resources > Server Capabilities to use the valid path to Java 1.8
@Foong below is maven configuration on bamboo server
mvn -v
Apache Maven 3.0.5 (Red Hat 3.0.5-17)
Maven home: /usr/share/maven
Java version: 1.8.0_171, vendor: Oracle Corporation
Java home: /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.171-7.b10.el7.x86_64/jre
Default locale: en_US, platform encoding: ANSI_X3.4-1968
OS name: "linux", version: "4.14.33-51.37.amzn1.x86_64", arch: "amd64", family
As you can see above java home on server is different from the path that is being referred in my build.
Can you please let me know the reason for this difference in configuration ?
Also i could see that latest JDK build is not getting reflected if i try to config manually.
PFB screenshot
Let me know your views on this.
Thanks in advance.
The path for "Build JDK" - JDK 1.8 have to be edited at Administration > Build Resources > Server Capabilities
Have you edited the JDK 1.8 capability at Administration > Build Resources > Server Capabilities ?
