When I run the build plan, doing git checkout fails with:
com.atlassian.bamboo.repository.RepositoryException: com.google.common.util.concurrent.UncheckedExecutionException: java.lang.IllegalArgumentException: Cannot read keypair, it doesn't contain any line with '-----BEGIN'
However, when I set up the repo and do "Test connection", the connection is good.
The id_rsa file which I provided begins with:
-----BEGIN RSA PRIVATE KEY-----
Proc-Type: 4,ENCRYPTED
DEK-Info:
I'm lost, please help me.
Hi!
If I understand correct, you have tried to configure plan.
But this way by default will work
if you follow this links
https://confluence.atlassian.com/bamboo/checking-out-code-289277060.html
https://confluence.atlassian.com/bamboo/git-289277007.html
BTW, you check your linked repositories here
{{BAMBOO_BASEURL}}/admin/configureLinkedRepositories!doDefault.action
I hope this is help for you.
Gonchik Tsymzhitov
Hi, thanks for the links. I checked those and it seems to me that I have done everything by the book. More screenshots below.
And your problem again reproduced?
What about key on git side? Is it accepted?
That was my original configuration and it again reproduced.
I'm not sure that I understand the question.
What seems to be happening is that my id_rsa is rejected. For example, the atlassian-bamboo.log reads:
2017-10-06 10:35:31,590 INFO [17-BAM::Default Agent::Agent:pool-32-thread-1] [BuildAgentControllerImpl] Agent 196609 checking build queue for executables...
2017-10-06 10:37:38,462 INFO [10-BAM::PlanExec:pool-17-thread-2] [DefaultErrorHandler] Recording an error: Unable to detect changes : VSR-E2E0 : com.google.common.util.concurrent.UncheckedExecutionException: java.lang.IllegalArgumentException: Cannot read keypair, it doesn't contain any line with '-----BEGIN'
2017-10-06 10:37:51,526 INFO [10-BAM::PlanExec:pool-17-thread-4] [DefaultErrorHandler] Recording an error: Unable to detect changes : VSR-E2E : java.lang.IllegalArgumentException: Cannot read keypair, it doesn't contain any line with '-----BEGIN'
The custom SSH key is a proper private key and its respective public key is listed under /home/ubuntu/.ssh/authorized_keys
Well,
1. What is your version Bamboo?
2. Do any other plans work under this instance? What about agents?
3.
It is good, but your agents knows about that?
Could you check it from agent directly?
Best regards,
Gonchik Tsymzhitov
Version 6.2.1, a new instance of Bamboo, trying to get the first plan off the ground.
3.
I am using the default agent, haven't applied any specific configurations for it.
Could you restart Bamboo?
In fact, it should work.
As I understand, you are already check this steps
