Hello!
I have a bamboo build with 2 stages: 1st Stage and 2nd Stage. How can I run manually 2nd Stage in case of 1st Stage failed?
Atlassian Bamboo version 7.1.4 build 70122 - 03 Nov 20
In case you have two independent process which should be executed regardless of status of another one, then put your tasks into different Jobs inside one Stage
In case you need to run tasks sequentially then put them to Stages, then Stage 2 will be executed after success of Stage 1
It's possible to mark Stage as Final, then Bamboo will trigger it regardless of status of previous stages. It's useful if you want to cleanup resources generated or taken by previous Stages
Thanks for different ways!
Does it mean that the only way to run Stage 2 sequentially it's successful Stage 1?
Yes if Stage 2 is regular stage.
If it's Final stage, then it will be executed after success or failure of Stage 1
