I'm running a Bamboo plan with a Bitbucket repository, but it failed imminently with code 128
Ivy Zhou September 18, 2019
Could anybody kindly help?
Version: Bamboo 6.9
Repository: Bitbucket Server
Error log:
java.lang.RuntimeException: com.atlassian.bamboo.plugins.stash.repository.StashRepositoryException
at com.atlassian.bamboo.executor.RetryingTaskExecutor.rerun(RetryingTaskExecutor.java:141)
at com.atlassian.bamboo.executor.RetryingTaskExecutor.runTask(RetryingTaskExecutor.java:99)
at com.atlassian.bamboo.executor.RetryingTaskExecutor.retry(RetryingTaskExecutor.java:207)
at com.atlassian.bamboo.executor.RetryingTaskExecutor.retry(RetryingTaskExecutor.java:188)
at com.atlassian.bamboo.plugins.vcs.task.VcsCheckoutTask.execute(VcsCheckoutTask.java:123)
at com.atlassian.bamboo.task.TaskExecutorImpl.lambda$executeTasks$3(TaskExecutorImpl.java:319)
at com.atlassian.bamboo.task.TaskExecutorImpl.executeTaskWithPrePostActions(TaskExecutorImpl.java:252)
at com.atlassian.bamboo.task.TaskExecutorImpl.executeTasks(TaskExecutorImpl.java:319)
at com.atlassian.bamboo.task.TaskExecutorImpl.executePreparationTasks(TaskExecutorImpl.java:91)
at com.atlassian.bamboo.build.pipeline.tasks.PrepareBuildTask.call(PrepareBuildTask.java:81)
at com.atlassian.bamboo.v2.build.agent.DefaultBuildAgent.executeBuildPhase(DefaultBuildAgent.java:204)
at com.atlassian.bamboo.v2.build.agent.DefaultBuildAgent.build(DefaultBuildAgent.java:176)
at com.atlassian.bamboo.v2.build.agent.BuildAgentControllerImpl.lambda$waitAndPerformBuild$0(BuildAgentControllerImpl.java:131)
at com.atlassian.bamboo.variable.CustomVariableContextImpl.withVariableSubstitutor(CustomVariableContextImpl.java:185)
at com.atlassian.bamboo.v2.build.agent.BuildAgentControllerImpl.waitAndPerformBuild(BuildAgentControllerImpl.java:125)
at com.atlassian.bamboo.v2.build.agent.DefaultBuildAgent$1.run(DefaultBuildAgent.java:127)
at com.atlassian.bamboo.utils.BambooRunnables$1.run(BambooRunnables.java:48)
at com.atlassian.bamboo.security.ImpersonationHelper.runWith(ImpersonationHelper.java:26)
at com.atlassian.bamboo.security.ImpersonationHelper.runWithSystemAuthority(ImpersonationHelper.java:17)
at com.atlassian.bamboo.security.ImpersonationHelper$1.run(ImpersonationHelper.java:41)
at java.lang.Thread.run(Thread.java:748)
Caused by: com.atlassian.bamboo.plugins.stash.repository.StashRepositoryException
at com.atlassian.bamboo.plugins.stash.v2.BitbucketServerWorkingCopyManager.retrieveSourceCode(BitbucketServerWorkingCopyManager.java:100)
at com.atlassian.bamboo.plugins.vcs.task.VcsCheckoutTask.fillWorkingDirFromVcs(VcsCheckoutTask.java:206)
at com.atlassian.bamboo.plugins.vcs.task.VcsCheckoutTask.access$000(VcsCheckoutTask.java:54)
at com.atlassian.bamboo.plugins.vcs.task.VcsCheckoutTask$1.call(VcsCheckoutTask.java:126)
at com.atlassian.bamboo.plugins.vcs.task.VcsCheckoutTask$1.call(VcsCheckoutTask.java:123)
at com.atlassian.bamboo.executor.RetryingTaskExecutor.rerun(RetryingTaskExecutor.java:112)
... 20 more
Caused by: com.atlassian.bamboo.repository.RepositoryException: Cannot fetch branch '(unresolved) HashAndSource{refName=[null], branch=[master], hash=[641a1d07e3105ba53cd80d26a701e7a826ad064e]}' from 'ssh://git@dc2ftxbtblv01.ipa.lmeft.co.uk:7999/mtcts/mtc-test-repository.git' to source directory '/root/bamboo-agent-home/xml-data/build-dir/_git-repositories-cache/ba39c814cb80d2284ac46e5849ec7a7fab76fe7f'. com.atlassian.bamboo.plugins.git.GitCommandException: command [/bin/git ls-remote ssh://a8c0935e-4c9a-4900-9b01-c074eeaeece8@127.0.0.1:43922/mtcts/mtc-test-repository.git] failed with code 128. Working directory was [/tmp]., stderr:
fatal: cannot exec '/tmp/bamboo-ssh.9900a68e.sh': Permission denied
fatal: unable to fork
at com.atlassian.bamboo.plugins.git.NativeGitOperationHelper.fetch(NativeGitOperationHelper.java:538)
at com.atlassian.bamboo.plugins.git.v2.GitWorkingCopyManager.lambda$checkout$1(GitWorkingCopyManager.java:253)
at io.atlassian.util.concurrent.ManagedLocks$ManagedLockImpl.withLock(ManagedLocks.java:293)
at com.atlassian.bamboo.plugins.git.v2.GitWorkingCopyManager.checkout(GitWorkingCopyManager.java:244)
at com.atlassian.bamboo.plugins.git.v2.GitWorkingCopyManager.retrieveSourceCode(GitWorkingCopyManager.java:102)
at com.atlassian.bamboo.plugins.stash.v2.BitbucketServerWorkingCopyManager.retrieveSourceCode(BitbucketServerWorkingCopyManager.java:90)
... 25 more
Caused by: com.google.common.util.concurrent.UncheckedExecutionException: com.atlassian.bamboo.plugins.git.GitCommandException: command [/bin/git ls-remote ssh://a8c0935e-4c9a-4900-9b01-c074eeaeece8@127.0.0.1:43922/mtcts/mtc-test-repository.git] failed with code 128. Working directory was [/tmp]., stderr:
at com.atlassian.bamboo.utils.collections.AlwaysInvalidatingCacheDecorator.getUnchecked(AlwaysInvalidatingCacheDecorator.java:128)
at com.atlassian.bamboo.util.CallableResultCache.call(CallableResultCache.java:142)
at com.atlassian.bamboo.plugins.git.NativeGitOperationHelper.getRemoteRefs(NativeGitOperationHelper.java:613)
at com.atlassian.bamboo.plugins.git.NativeGitOperationHelper.resolveBranch(NativeGitOperationHelper.java:565)
at com.atlassian.bamboo.plugins.git.NativeGitOperationHelper.getRefsToFetch(NativeGitOperationHelper.java:555)
at com.atlassian.bamboo.plugins.git.NativeGitOperationHelper.fetch(NativeGitOperationHelper.java:516)
... 30 more
Caused by: com.atlassian.bamboo.plugins.git.GitCommandException: command [/bin/git ls-remote ssh://a8c0935e-4c9a-4900-9b01-c074eeaeece8@127.0.0.1:43922/mtcts/mtc-test-repository.git] failed with code 128. Working directory was [/tmp]., stderr:
at com.atlassian.bamboo.plugins.git.GitCommandProcessor.runCommand(GitCommandProcessor.java:723)
at com.atlassian.bamboo.plugins.git.GitCommandProcessor.getRemoteRefs(GitCommandProcessor.java:499)
at com.atlassian.bamboo.plugins.git.NativeGitOperationHelper.lambda$getRemoteRefs$1(NativeGitOperationHelper.java:605)
at com.atlassian.bamboo.util.CallableResultCache$1.load(CallableResultCache.java:39)
at com.atlassian.bamboo.util.CallableResultCache$1.load(CallableResultCache.java:35)
at com.google.common.cache.LocalCache$LoadingValueReference.loadFuture(LocalCache.java:3527)
at com.google.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2319)
at com.google.common.cache.LocalCache$Segment.lockedGetOrLoad(LocalCache.java:2282)
at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2197)
at com.google.common.cache.LocalCache.get(LocalCache.java:3937)
at com.google.common.cache.LocalCache.getOrLoad(LocalCache.java:3941)
at com.google.common.cache.LocalCache$LocalLoadingCache.get(LocalCache.java:4824)
at com.atlassian.bamboo.utils.collections.AlwaysInvalidatingCacheDecorator.get(AlwaysInvalidatingCacheDecorator.java:65)
at com.atlassian.bamboo.utils.collections.AlwaysInvalidatingCacheDecorator.getUnchecked(AlwaysInvalidatingCacheDecorator.java:126)
... 35 more
Close This Window
| Report bug Report Bug
Petr Vaníček
September 18, 2019
Did you configure in any job step custom (/tmp) working directory?
If yes, then try to set only tmp instead of /tmp or give permission to this folder to bamboo user.
Thanks Petr for your kindly help.
Actually I'm not sure about it. The env is built by the other guy and I just have the limit rights. Do you have any ideas to check the working directory? Is the bamboo user you mentioned who I log on the Bamboo?
Thanks again
Petr Vaníček
September 19, 2019
Did you configure plan and jobs inside? You can see problem in this part of your log.
With user I mean system user. Look in documentation for Bamboo's operationg system.
https://confluence.atlassian.com/bamboo/running-bamboo-as-a-service-628720223.html
Ivy Zhou September 19, 2019
Thanks very much Petr.
Yes, it works after i asked someone to change the working directory.
Ankit Gupta
November 9, 2022
how did you changed the working directory ?
