Hi, here is little diagram:
Env1 and Env2 are deployed in parallel by deployment plan; Final env shall be triggered manually whenever suited. I want to safeguard myself from situation, when someone triggers final environment manually before Env1 or Env2 have finished execution.
Is it possible by standard means of Bamboo or I shall go into scripting?
we don't have any mechanism in Bamboo to can prevent that.
I was trying to find a way to solve this problem and the best I could think of was somehow failing the final deployment when the results of Env1 and Env2 are still not available.
We don't have such restrictions or dependence between environments.
Yes, I would like to see it as a feature request, possibly coupled with another possibility: "and" behavior for Environment deployment switch (so, Final env shall be possible to start via Successful deployment trigger, which starts it only in case both envs are OK).
Format of a feature - maybe a dropbox at environment configuration which will say that environment is dependent on some other environments (so, I could select several with checkboxes, much like rights are assigned).
Can you advise on API call which I can use to track the status of previous environments?
Hi @Anton_Kuryan
I'm sorry for the delay here, I needed some quiet time to work on this and it was difficult to find.
This is the feature request I created based on your comment:
This is a feature request that is related to the one we just created and could be of your interest:
I created this community article to allow you getting the environment result information you need from REST API:
Please add yourself as a watcher and vote in the feature requests above. If you have more comments on this matter, just let me know.
You are welcome! =]
