Is there a way to create deploy project variable similar to the build plan variable?
Aleksey Nosik
September 16, 2018
We have common deploy project variables that are the same for each deployment environment. The only way I see currently is to use global variables, but I don't want these variables/values to be visible from other deployment projects.
Currently, I had to declare the same variables for each environment. As a workaround, maybe you can point how to clone environment, to be able to create one and reassign variable values after cloning.
Gabriel Ribeiro
September 19, 2018
Hi Aleksey,
I'm afraid this is currently not possible, there is an open improvement request asking for this but it didn't get the necessary votes to be implemented yet.
I encourage you to vote on and watch the Improvement Request to increase its visibility and ensure you're kept in the loop with any future updates.
thanks
Aleksey Nosik
September 20, 2018
Thank you! Upvoted it
