Problems with encoding Bamboo
Aleksandra Maslennikova March 29, 2018
Hello.
There is a instruction:
https://confluence.atlassian.com/bamkb/how-to-change-the-wrong-encoding-in-bamboo-that-is-causing-the-application-to-crash-318670134.html
I can't find file conf/wrapper.conf in Windows OS.
Where is it?
Ellie Z
March 30, 2018
Hi Aleksandra,
Thanks for reaching out to the Atlassian Community!
If you're using Bamboo 5.1.0 or above, and running Bamboo from the Console, you'll want to put the variables into
<bamboo-install>\bin\setenv.bat
This is commonly in a location such as
C:\Program Files\Bamboo\bin\setenv.bat
Before Bamboo 6.2.0, the variable would look like this:
JVM_SUPPORT_RECOMMENDED_ARGS="-Dfile.encoding=utf-8 -Dsun.jnu.encoding=utf-8"
For Bamboo 6.2.0 and above, it would be like this:
: ${JVM_SUPPORT_RECOMMENDED_ARGS:="-Dfile.encoding=utf-8 -Dsun.jnu.encoding=utf-8"}
However, if you are running Bamboo as a Service, you'll need to use the Tomcat Service properties to do this. Instructions to do this would be in the following documentation:
Configuring your system properties
In this case, please be sure to add each of the parameters on its own line, as described in the article linked above.
I hope this helps you get Bamboo running on the correct encoding!
Elias | Bamboo Support
Aleksandra Maslennikova April 5, 2018
Elias,
Thank you for your help
Ellie Z
April 6, 2018
Hi Aleksandra!
You are most welcome! If this solution helped you, may I ask that you please mark this answer as "Accepted" by clicking on the check mark? This will allow other users to find this post easier.
Thanks again for reaching out to us!
Best,
