Hello, i am new in bamboo so please bare with me .
I have installed bamboo trial at my machine
Created a project, Added Bit bucket repository to the project, also added MS test builder as a task in project
Now i really don''t know what to do further to build my project and run my unit tests under bamboo. Need guidance any documentation over it would be helpful
Regards
@armanhussaingt could you get it to work?
Hi Arman,
I'm not sure if I understood it correctly but the next step depends on what you want to do next. If you were building your project manually what would be next phase?
If you have questions on how to configure the test tasks, please take a look at the following documentation and let us know if it was helpful:
Thanks for the response and sorry for my late reply as i was busy with some other things . Let me look into the link you shared above and then i will get back to you
Regards
@Gabriel Ribeiro I configured a task as Mstest Runner as i am working with .net unit tests now how to execute it ?
