Specs - How to set custom plan branch for deployment project
Pedro Sa da costa January 13, 2020
Using Java specs, how can I set a custom plan branch for a deployment project?
In the UI this option is under `/deploy/config/configureDeploymentProjectDetails` .
If this is not possible, is it possible in any other way to mass configure different deployment plans for the same build plan  being ran on different branches?
Best Regards,
Pedro
Alexey Chystoprudov
January 14, 2020
Configure custom branch for deployment project through UI and then use menu item "View as Java Specs". It will generate Java code for current deployment project
Pedro Sa da costa January 14, 2020
Hello Alexey,
Thanks for the tip, I can see now that the PlanIdentifier ID number changes for each branch. This was not oblivious from the API.
Thank you for your help!
After fiddling with this some more, this allows me to edit existing branches, but not to create new ones since I'm missing a BambooOid. Can this Id be retrieved somehow (using the API, or the GUI) from an existing build branch and not an existing deployment plan?
Alexey Chystoprudov
January 14, 2020
It's enough to use PlanIdentifier without oid
final Deployment rootObject = new Deployment(new PlanIdentifier("COM", "PLAN10")), "Test")
Like Pedro Sa da costa likes this
Unfortunately that does not work for me when creating a new deployment:
val deploymentName = "Tomcat Alpha deployment ${env.name.toUpperCase()}"
val planIdentifier = PlanIdentifier(Vars.PROJECT_KEY, env.bambooPlanId)
Deployment(planIdentifier, deploymentName)
// error
// Can't find deployment project by oid(null) or name(Tomcat Alpha deployment TEST)
Vars.PROJECT_KEY,  and env.bambooPlanId match the IDs i can see in the bamboo plan generated java specs if I create it manually.
Alexey Chystoprudov
January 14, 2020
This error message is from deployment permissions import.
Are you sure it's related to plan branches selection from topic header?
You are correct!
The problem was indeed from the permissions import. I was doing them before publishing the specs, which would cause an error when creating , but not when updating an existing plan.
