Sql Query for Bamboo Deployments and related artifacts?
Tim Finch March 12, 2019
Is there any way of querying the Bamboo database to bring back details of each time a deployment was run, to which environment and what artifacts were involved?
I have (thanks to another question on here) got the first part:-
SELECT dp.name AS deploy_name, de.name AS env_name, dr.started_date, dr.queued_date, dr.executed_date, dr.finished_date
FROM deployment_project dp, deployment_environment de, deployment_result dr
WHERE dp.deployment_project_id = de.package_definition_id
AND de.environment_id = dr.environment_id
AND de.name = '<Your_Environment_Name_Here>'
However, I'd like to tie into the results returned the ability to see what artifacts are linked to each deployment.
Is this possible?
Daniel Santos
March 13, 2019
Hi @Tim Finch
Yes, after some deeper investigation.
Can you please check if this will address your needs:
SELECT DP.NAME,
DE.NAME,
DR.STARTED_DATE,
DR.QUEUED_DATE,
DR.EXECUTED_DATE,
DR.FINISHED_DATE,
DV.NAME,
DV.PLAN_BRANCH_NAME,
DV.CREATOR_USERNAME,
DVIB.*
FROM DEPLOYMENT_PROJECT DP
JOIN DEPLOYMENT_ENVIRONMENT DE ON DP.DEPLOYMENT_PROJECT_ID = DE.PACKAGE_DEFINITION_ID
JOIN DEPLOYMENT_RESULT DR ON DE.ENVIRONMENT_ID = DR.ENVIRONMENT_ID
JOIN DEPLOYMENT_VERSION DV ON DV.DEPLOYMENT_VERSION_ID=DR.VERSION_ID
JOIN DEPLOYMENT_VERSION_ITEM DVI ON DVI.DEPLOYMENT_VERSION_ID=DV.DEPLOYMENT_VERSION_ID
JOIN DEPLOYMENT_VERSION_ITEM_BA DVIB ON DVIB.VERSION_BAM_ARTIFACT_ITEM_ID=DVI.DEPLOYMENT_VERSION_ITEM_ID
WHERE DE.NAME = '<ENVIRONMENT_NAME>'
I'll wait for your findings.
Tim Finch March 18, 2019
Thanks @Daniel Santos
From my perspective this looks fantastic and works successfully.
I have sent the data to the relevant delivery teams to ensure it also meets their criteria.
Thank you for your help.
Tim
Daniel Santos
March 18, 2019
You are welcome @Tim Finch
If you don't mind, when you confirm this, please accept the answer as a solution to help other Community users on finding it.
Like # people like this
