Hi! I'm using build plan branches for the first time, and can't get it to work. When I attempt to run a build for my branch, I get the following error. Any help is appreciated.
java.lang.IllegalArgumentException: Unknown RepositoryDefinition 9994243 at com.atlassian.bamboo.v2.build.BuildChangesImpl.getBuildRepositoryChanges(BuildChangesImpl.java:213) at com.atlassian.bamboo.v2.build.BuildChangesImpl.setPreviousVcsRevisionKey(BuildChangesImpl.java:92) at com.atlassian.bamboo.plan.vcsRevision.PlanVcsRevisionHistoryManagerImpl.markBuildStartedNewTx(PlanVcsRevisionHistoryManagerImpl.java:60) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:497) at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:317) at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:190) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:157) at org.springframework.transaction.interceptor.TransactionInterceptor$1.proceedWithInvocation(TransactionInterceptor.java:98) at org.springframework.transaction.interceptor.TransactionAspectSupport.invokeWithinTransaction(TransactionAspectSupport.java:262) at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:95) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179) at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:207) at com.sun.proxy.$Proxy138.markBuildStartedNewTx(Unknown Source) at com.atlassian.bamboo.plan.vcsRevision.PlanVcsRevisionHistoryServiceImpl$2.run(PlanVcsRevisionHistoryServiceImpl.java:53) at com.atlassian.util.concurrent.ManagedLocks$ManagedLockImpl.withLock(ManagedLocks.java:321) at com.atlassian.bamboo.plan.vcsRevision.PlanVcsRevisionHistoryServiceImpl.markBuildStarted(PlanVcsRevisionHistoryServiceImpl.java:48) at com.atlassian.bamboo.chains.ChainExecutionManagerImpl.tryStartChainState(ChainExecutionManagerImpl.java:313) at com.atlassian.bamboo.chains.ChainExecutionManagerImpl.delayedStart(ChainExecutionManagerImpl.java:224) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.lang.reflect.Method.invoke(Method.java:497) at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:317) at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:190) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:157) at org.springframework.aop.interceptor.ExposeInvocationInterceptor.invoke(ExposeInvocationInterceptor.java:92) at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179) at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:207) at com.sun.proxy.$Proxy151.delayedStart(Unknown Source) at com.atlassian.bamboo.plan.PlanExecutionManagerImpl$2$1$1$1.run(PlanExecutionManagerImpl.java:430) at com.atlassian.bamboo.util.CacheAwareness$2.call(CacheAwareness.java:83) at com.atlassian.bamboo.util.CacheAwareness$2.call(CacheAwareness.java:79) at com.atlassian.bamboo.util.CacheAwareness.whileReadingThroughCaches(CacheAwareness.java:101) at com.atlassian.bamboo.util.CacheAwareness.whileReadingThroughCaches(CacheAwareness.java:78) at com.atlassian.bamboo.util.CacheAwareness.whileReadingThroughCaches(CacheAwareness.java:118) at com.atlassian.bamboo.plan.PlanExecutionManagerImpl$2$1$1.call(PlanExecutionManagerImpl.java:425) at com.atlassian.bamboo.plan.PlanExecutionManagerImpl$2$1$1.call(PlanExecutionManagerImpl.java:416) at com.atlassian.util.concurrent.ManagedLocks$ManagedLockImpl.withLock(ManagedLocks.java:312) at com.atlassian.bamboo.plan.PlanExecutionLockServiceImpl.lock(PlanExecutionLockServiceImpl.java:85) at com.atlassian.bamboo.plan.PlanExecutionManagerImpl.doWithProcessLock(PlanExecutionManagerImpl.java:801) at com.atlassian.bamboo.plan.PlanExecutionManagerImpl.access$400(PlanExecutionManagerImpl.java:128) at com.atlassian.bamboo.plan.PlanExecutionManagerImpl$2$1.run(PlanExecutionManagerImpl.java:410) at com.atlassian.bamboo.utils.BambooRunnables$1.run(BambooRunnables.java:49) at com.atlassian.bamboo.security.ImpersonationHelper.runWith(ImpersonationHelper.java:31) at com.atlassian.bamboo.security.ImpersonationHelper.runWithSystemAuthority(ImpersonationHelper.java:20) at com.atlassian.bamboo.security.ImpersonationHelper$1.run(ImpersonationHelper.java:52) at java.lang.Thread.run(Thread.java:745)
Hello Matthew,
Thank you for your inquire.
The error above related to the fact that at certain moment there was a repository with ID 9994243 and, for some reason (i.e.: deletion) the same is no longer available to the Plan you are attempting on running. That said, please:
If you find this answer useful, I would kindly ask you to accept it so the same will be visible to others who might be facing the same issue you have inquired.
Thank you for your understanding.
Rafael P. Sperafico
Atlassian Support
I am facing the same issue and I have made sure the 4 points mentioned in your answer. I removed the linked repository and added it again as well. Still facing this issue.
Is this fixed? Any workaround for this?
Had the same problem today with 7.1.2.
The only way I could resolve it is to run a new custom build with the same params as the failing one (rebuilds didn't work)
Ok here is the symptoms and a quicker fix:
1) build is queued
2) build is not seen in the system build queue
3) When build stopped, repo error will appear
Fix:
1) Create a linked repo with the settings but different name.
2) swap it out with the default repo for the build plan.
