Was not able to determine current branch for branch plug-in mode
Kia Armani
January 18, 2019
Hello there,
I am trying to setup the branching feature in Bamboo for our repository, but I am running into issues with running automated builds.
The first automated build worked, but every build after that one results in this exception:
java.lang.IllegalStateException: Was not able to determine current branch for branch plug-in mode
	at ch.mibex.bamboo.sonar4bamboo.tasks.SonarRuntimeDataProvider$$anonfun$setBranchTargetName$1.apply(SonarRuntimeDataProvider.scala:148)
	at ch.mibex.bamboo.sonar4bamboo.tasks.SonarRuntimeDataProvider$$anonfun$setBranchTargetName$1.apply(SonarRuntimeDataProvider.scala:143)
	at scala.Option.foreach(Option.scala:256)
	at ch.mibex.bamboo.sonar4bamboo.tasks.SonarRuntimeDataProvider.setBranchTargetName(SonarRuntimeDataProvider.scala:143)
	at ch.mibex.bamboo.sonar4bamboo.tasks.SonarRuntimeDataProvider.populateRuntimeTaskData(SonarRuntimeDataProvider.scala:51)
	at com.atlassian.bamboo.chains.ChainPluginSupportHelper.lambda$prepareRuntimeTaskData$0(ChainPluginSupportHelper.java:37)
	at java.util.stream.ForEachOps$ForEachOp$OfRef.accept(ForEachOps.java:184)
	at java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:193)
	at java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:175)
	at java.util.ArrayList$ArrayListSpliterator.forEachRemaining(ArrayList.java:1374)
	at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:481)
	at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:471)
	at java.util.stream.ForEachOps$ForEachOp.evaluateSequential(ForEachOps.java:151)
	at java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(ForEachOps.java:174)
	at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)
	at java.util.stream.ReferencePipeline.forEach(ReferencePipeline.java:418)
	at com.atlassian.bamboo.chains.ChainPluginSupportHelper.prepareRuntimeTaskData(ChainPluginSupportHelper.java:31)
	at com.atlassian.bamboo.chains.ChainPluginSupportImpl$10.run(ChainPluginSupportImpl.java:242)
	at com.atlassian.bamboo.variable.CustomVariableContextImpl.withVariableSubstitutor(CustomVariableContextImpl.java:174)
	at com.atlassian.bamboo.variable.CustomVariableContextRunnerImpl.execute(CustomVariableContextRunnerImpl.java:31)
	at com.atlassian.bamboo.chains.ChainPluginSupportImpl.buildStarted(ChainPluginSupportImpl.java:233)
	at sun.reflect.GeneratedMethodAccessor1949.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.lang.reflect.Method.invoke(Method.java:497)
	at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:343)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:197)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:163)
	at org.springframework.orm.hibernate5.support.OpenSessionInterceptor.invoke(OpenSessionInterceptor.java:90)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:185)
	at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:212)
	at com.sun.proxy.$Proxy242.buildStarted(Unknown Source)
	at com.atlassian.bamboo.chains.ChainExecutionManagerImpl.dispatchBuildsInCurrentStage(ChainExecutionManagerImpl.java:883)
	at com.atlassian.bamboo.chains.ChainExecutionManagerImpl.access$2000(ChainExecutionManagerImpl.java:127)
	at com.atlassian.bamboo.chains.ChainExecutionManagerImpl$4.run(ChainExecutionManagerImpl.java:625)
	at io.atlassian.util.concurrent.ManagedLocks$ManagedLockImpl.withLock(ManagedLocks.java:302)
	at com.atlassian.bamboo.chains.ChainExecutionManagerImpl.execute(ChainExecutionManagerImpl.java:581)
	at com.atlassian.bamboo.chains.ChainExecutionManagerImpl.tryStartChainState(ChainExecutionManagerImpl.java:340)
	at com.atlassian.bamboo.chains.ChainExecutionManagerImpl.delayedStart(ChainExecutionManagerImpl.java:232)
	at sun.reflect.GeneratedMethodAccessor1743.invoke(Unknown Source)
	at org.springframework.aop.interceptor.ExposeInvocationInterceptor.invoke(ExposeInvocationInterceptor.java:92)
	at com.sun.proxy.$Proxy225.delayedStart(Unknown Source)
	at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:206)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl$1$1$1.lambda$call$0(PlanExecutionManagerImpl.java:374)
	at com.atlassian.bamboo.util.CacheAwareness$3.call(CacheAwareness.java:136)
	at com.atlassian.bamboo.util.CacheAwareness$3.call(CacheAwareness.java:133)
	at com.atlassian.bamboo.util.CacheAwareness.withValuesOlderThanTimestampReloaded(CacheAwareness.java:162)
	at com.atlassian.bamboo.util.CacheAwareness.withValuesOlderThanTimestampReloaded(CacheAwareness.java:133)
	at com.atlassian.bamboo.util.CacheAwareness.withValuesOlderThanTimestampReloaded(CacheAwareness.java:187)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl$1$1$1.call(PlanExecutionManagerImpl.java:373)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl$1$1$1.call(PlanExecutionManagerImpl.java:366)
	at io.atlassian.util.concurrent.ManagedLocks$ManagedLockImpl.withLock(ManagedLocks.java:293)
	at com.atlassian.bamboo.plan.PlanExecutionLockServiceImpl.lock(PlanExecutionLockServiceImpl.java:75)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl.doWithProcessLock(PlanExecutionManagerImpl.java:655)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl.access$400(PlanExecutionManagerImpl.java:130)
	at com.atlassian.bamboo.plan.PlanExecutionManagerImpl$1$1.run(PlanExecutionManagerImpl.java:362)
	at com.atlassian.bamboo.utils.BambooRunnables$1.run(BambooRunnables.java:48)
	at com.atlassian.bamboo.security.ImpersonationHelper.runWith(ImpersonationHelper.java:26)
	at com.atlassian.bamboo.security.ImpersonationHelper.runWithSystemAuthority(ImpersonationHelper.java:17)
	at com.atlassian.bamboo.security.ImpersonationHelper$1.run(ImpersonationHelper.java:41)
	at java.lang.Thread.run(Thread.java:745)
Michael Rüegg _Mibex Software_
January 18, 2019
This error normally comes up when you have enabled incremental mode and/or the QG status build breaker feature, but do not use a Bitbucket Server repository in your build plan.
Is that possible?
Best regards,
Michael (app vendor)
Kia Armani
January 20, 2019
I do not use incremental mode, but I use the QG status build breaker feature. The build plan contains two repositorys from a Bitbucket Server.
January 20, 2019
@Kia ArmaniThanks for your feedback. Could you please create a support request at https://support.mibexsoftware.com including the debug logs of the app? That would help us a lot in reproducing the issue.
Foong
January 18, 2019
The error happens at the Sonar task.
Contact the developer of the Sonar add-on here
