bamboo.plan.directory.info.rest system property is disabled by default. How to set it to local?
Nikita Bedmutha June 18, 2018
As per https://confluence.atlassian.com/bamboo/plan-directory-information-rest-api-750396160.html, 'bamboo.plan.directory.info.rest' property is set to disabled by default. I want to make teh REST call to /rest/api/latest/planDirectoryInfo/{planKey} but i am getting 401 Access denied. I suspect we need to modify the disabled property to local or authenticated. But where to find this property? in which file ?
Steffen Opel _Utoolity_
As outlined in more detail within Plan directory information REST API, the "bamboo.plan.directory.info.rest is a system property with the following settings":
disabled (default)
The plan directory information REST API is disabled and all requests will be rejected
local
The plan directory information REST API is available without authentication to any request originating from localhost
anonymous
The plan directory information REST API is accessible anonymously
authenticated
The plan directory information REST API is accessible to any authenticated request
authenticated-admin
The plan directory information REST API is accessible to any request authenticated as an administrator
Please refer to Configuring your system properties for details on the various options "how to set Java properties and options on startup for Bamboo".
Alexey Matveev
June 18, 2018
401 error means that you are not authenticated. How do you make the REST call? Do you pass the authorization info?
Yes, I pass the username and password as Basic Auth
