Run build button is missing for Test Build Plan
Scott Walch
August 1, 2014
I have a Dev, Test and Prod build plan. When I run my Dev build manually, I have a "run" button to kick it off. I also have a run button for my Prod plan. For some reason, my "run" button has disappeard from my Test plan. What would cause that to happen?
Scott
Gretchen
August 3, 2014
Permission changes on that plan. Make sure you have "build" permisions on the Test plan.
Scott Walch
August 3, 2014
This was the issue, apparently the permissions changed and the button disappeard. I now have my permissions restored, and all is well.
Krystian Brazulewicz
August 1, 2014
Scott - can you post screenshots?
