SCP identity agent key invalid problem
hkulekci March 21, 2018
I am getting below error while coping some files with scp task
2018-03-21 07:19:00,116 INFO [17-BAM::Default Agent::Agent:pool-32-thread-1] [TransportImpl] Client identity string: SSH-2.0-SSHJ_0.21.12018-03-21 07:19:00,182 WARN [17-BAM::Default Agent::Agent:pool-32-thread-1] [IdentificationStringParser] Server identification has bad line ending, was expecting a '\r\n' however got: '2' (hex: 32)2018-03-21 07:19:00,183 WARN [17-BAM::Default Agent::Agent:pool-32-thread-1] [IdentificationStringParser] Will treat the identification of this server 'SSH-2.0-OpenSSH_7.4p1 Debian-10+deb9u2' leniently
This error started getting after changing remote server without changing IP.
Anonymous Coward
Simon says:
On your remote SSH server (the one that is the destination of the copy operation) configuration set the following option:
DebianBanner no
and restart the remote SSH server. This will transform the SSH banner to  SSH-2.0-OpenSSH_7.4p1.
On some other distribution you may have to use instead the option:
VersionAddendum none
in the SSH server configuration on the remote host.
Cheers, Simon out.
hkulekci March 22, 2018
Hello Simon, I tried both but not work for me. The result is the same.
Jeyanthan I
March 31, 2018
Do you get the same error when you execute the scp command from the terminal as the same user outside Bamboo?
If it didn't error out, you may use the script task instead of scp task where you can define your scp command.
hkulekci October 29, 2018
I used script instead of scp task. I guess scp task cache the ip addresses or ssh library of java cache the ip address. And the ip changed for same server. The scp task give this error interestingly.
Jeyanthan I
October 29, 2018
Ah, good catch. Thanks for sharing it here :)
