Setting Bamboo build expiry without affecting artifacts for deployment projects
Simon Boland December 26, 2017
I have numerous build plans (around 25).  A small number of these are configured with deployment projects.
If I expire the build artifacts will it mean that I can potentially lose the artifacts which were saved for the releases in the deployment plans?
Is there a way I can avoid this?  The only way I can think to do this is by applying a label.
I discover Bamboo deployments keeps these so it's not an issue.  I just didn't see it mentioned in the documentation.
