Using Json Parser.Build result is not coming properly.i am getting this error.Failed to parse test result file
Hey Sumit, can you give us more details about this problem? What task are you using to parse your tests? How your report is generated?
If this is Junit parser, please check this link: JUnit Parser task in Bamboo shows 'Failed to parse test result file' error when parsing test results file
