Using MS SQL Integrated Authentication with Bamboo and Fisheye
Chris Wundram
I am confugring Bamboo and Fisheye to use a Microsoft SQL database server. Our DBAs would like us to use integrated authentication instead of SQL authentication. I was able to configure this for Stash, but not for Bamboo or Fisheye. Has anyone been able to configure these apps for integrated authentication?
Foong
May 21, 2013
Hi Chris,
Please try the following workaround in a test server:
  1. Integrate Bamboo/FishEye to SQL Server through the UI
  2. Stop Bamboo/FishEye
  3. Copy sqljdbc-*.jar driver from STASH_INSTALL/lib into BAMBOO_INSTALL/webapp/WEB-INF/lib or FISHEYE_INST/lib
  4. Copy x64 or x86 from STASH_INSTALL/lib/native and rename it as sqljdbc_auth.dll into BAMBOO_INSTALL/webapp/WEB-INF/lib or FISHEYE_INST/lib
  5. Modify BAMBOO_HOME/bamboo.cfg.xml or FISHEYE_INST/config.xmlto have the new settings:
    Bamboo:
    <properties>
        <property name="hibernate.connection.driver_class">com.microsoft.sqlserver.jdbc.SQLServerDriver</property>
        <property name="hibernate.connection.password"></property>
        <property name="hibernate.connection.url">jdbc:sqlserver://CONFSERVER:1433;databaseName=Confluence;integratedSecurity=true;</property>
        <property name="hibernate.connection.username">sa</property>
    </properties>
    FishEye:
    	<database type="sqlserver2008">
    		<connection dialect="com.cenqua.crucible.hibernate.dialects.SQLServer2008UnicodeDialect" driver="com.microsoft.sqlserver.jdbc.SQLServerDriver" jdbcurl="jdbc:sqlserver://localhost:1433;databaseName=fisheye;integratedSecurity=true;" password="" username="sa" maxPoolSize="20" minPoolSize="5" driverSource="user"/>
    	</database>
    Change the value mentioned in the above example only. Do not delete other settings in the file.
  6. Start Bamboo/FishEye
Source: https://confluence.atlassian.com/display/DOC/Database+Setup+for+SQL+Server?focusedCommentId=132383179#comment-132383179
StevenHawkins July 3, 2017
Update;
For Bamboo 6 at least, the sqljdbc_auth.dll should be placed in <bamboo-install>/bin
Neil
Did this solution work for you? I am going to attempt this shortly so I am looking for any updated information on this for the most recent Fisheye. Thanks!
