×Dear All
I'm use bamboo 5.15.5 (upgrade 5.15.3)
I get a return url error when I click the build round after clicking tab in Build Result. (Add Context root name)
Normal Case Build Result Url
: .....gotoBuildResult.action....&returnUrl=%2Fbrowse
When Build Result Tab(Tests, Commits, logs...) Result Url
: - .....gotoBuildResult.action....&returnUrl=bamboo%2Fbrowse
bamboo is my context root name
so, url is
http://mybambooip:port/bamboo/build/result/bamboo/browse/
(Unnecessary url : build/result/bamboo)
This does not happen with chrome. It only occurs in IE (11).
It did not occur in version 5.15.3.
Help me please
Thank you.
Hi!
Please, don't forget the supported platform page
https://confluence.atlassian.com/bamboo/supported-platforms-289276764.html
BTW, are you on the latest version 6.8.0 or planning?
https://confluence.atlassian.com/bamboo/bamboo-releases-671089224.html
Gonchik Tsymzhitov
