Why does my git checkout not work ?
james_mccutcheon
December 22, 2015
I am running bamboo elastic solution and this is my log when doing a code checkout from my Git bitbucket account:
simple	23-Dec-2015 10:03:31	Starting task 'Checkout' of type 'com.atlassian.bamboo.plugins.vcs:task.vcs.checkout'
simple	23-Dec-2015 10:03:31	Build always requires a clean checkout
simple	23-Dec-2015 10:03:31	Cleaning build directory 'C:\build\CON-TEST-JOB1'
simple	23-Dec-2015 10:03:31	Updating source code to revision: 4d35c967b3aecf2f6130ed21cb503b7b8069fb87
simple	23-Dec-2015 10:03:31	C:\cygwin\bin\git.exe version
simple	23-Dec-2015 10:03:32	Updating source code to revision: 4d35c967b3aecf2f6130ed21cb503b7b8069fb87
simple	23-Dec-2015 10:03:32	C:\cygwin\bin\git.exe version
simple	23-Dec-2015 10:03:32	Task was canceled - 'Checkout(4)' of type com.atlassian.bamboo.plugins.vcs:task.vcs.checkout.
not sure why its running "git version" for ?
if I do a git clone via a script it works fine and its downloaded
rrudnicki
December 22, 2015
Hi James,
I found the answer below which looks very similar to your case. This looks to be related to a different version of Git between Bamboo Agent and Server. Please have a look:
https://answers.atlassian.com/questions/32116318/setting-up-for-bitbucket
Renato Rudnicki
james_mccutcheon
December 22, 2015
Firstly thanks for taking the time to respond.
Yes its windows, as for cygwin ... all the AWS elastic images provided by Atlassian has cygwin git installed so I assume it would work. The only versions that dont are old images running on 2008 servers but considering this is using their default image and their default run job then I am guessing that would work.
Mike Friedrich
December 22, 2015
I am assuming that's Windows, I am not familiar with the elastic thing. Are you sure the cygwin git works in bamboo? I have been always using Git for Windows.
