I am trying to install Bamboo and am having problems starting:
sudo
./start-bamboo.sh -fg
Server startup logs are located in /opt/atlassian/atlassian-bamboo-6.10.3/bin/logs/catalina.out
Bamboo Server Edition
Version : 6.10.3
If you encounter issues starting or stopping Bamboo Server, please see the Troubleshooting guide at https://confluence.atlassian.com/display/BAMBOO/Installing+and+upgrading+Bamboo
Using CATALINA_BASE: /opt/atlassian/atlassian-bamboo-6.10.3
Using CATALINA_HOME: /opt/atlassian/atlassian-bamboo-6.10.3
Using CATALINA_TMPDIR: /opt/atlassian/atlassian-bamboo-6.10.3/temp
Using JRE_HOME: /usr/lib/jvm/java-1.11.0-openjdk-amd64/bin
Using CLASSPATH: /opt/atlassian/atlassian-bamboo-6.10.3/bin/bootstrap.jar:/opt/atlassian/atlassian-bamboo-6.10.3/bin/tomcat-juli.jar
/opt/atlassian/atlassian-bamboo-6.10.3/bin/catalina.sh: 1: exec: /usr/lib/jvm/java-1.11.0-openjdk-amd64/bin/bin/java: not found
I can’t understand why the start script adds bin / java to the JAVA_HOME path again.
Thank you, this guide is not complete enough. I did the same as the guide for Jira, and I did it.
I skipped some steps that are described in the guide for Jira, but they are not in the guide for Bamboo
Hi @Иван_Пузырёв ,
you should configure your JAVA_HOME to point to the main folder of the JDK, as the Bamboo script will automatically add the "/bin/java" to JAVA_HOME.
Let me know if you have any questions,
--Alexis
Hi, thanks for the feedback.
What does this mean "main folder"?
echo $JAVA_HOME
echo $JRE_HOME
I think that in all environment variables the correct values are indicated
I get it. The problems were really with setting user paths for various users, including root.
Is there a guide for setting up a user for Bamboo and permissions to run?
Hi @Иван_Пузырёв ,
there is a detailed guide here : https://confluence.atlassian.com/bamboo/installing-bamboo-on-linux-289276792.html.
It should give you all the information on how to install Bamboo.
--Alexis
