changing bamboo project key
Deleted user June 1, 2015
Hi Team,
Greetings of the day !!!
I have one doubt, I know how to change the name of a particulr project in Bamboo. But it will still have the old project key. Is there any way to change the project key as well?
Thank you in advance smile
Warm Regards,
-Jewel
Dirk Bromberg
June 1, 2015
you can move a plan to a new project with a new key.
Goto Admin->Plans->Move plans
or enter: http://bambooURL/admin/chooseBuildsToMove.action
Then you can move them to a new project.
Regards, Dirk
Hi, So you're saying that there is no way to edit a project key? What about plan key. I read somewhere (I think in some atlassian site) that it is not possible. Regards, -Jewel
Dirk Bromberg
June 1, 2015
Yes I think there is no good way. Maybe in the database behind. But the keys are also reflected by the filesystem in bamboo home. So this not so easy.
Thanks Dirk !!
Krystian Brazulewicz
June 9, 2015
If you're changing the key for a plan with lots of results it is advised to create a backup of your Bamboo home directory and database before running this operation.
