how do I know how my build plan was triggered: manually or automatically (night)?
e
Hello, I am using Bamboo 5.4.2
How do I know how my build plan was triggered: manually or automatically (night)?
I want to write a script that will react accordingly, depending on whether the build was started manually or automatically (scheduled).
I expect there to be some kind of a variable like ${bamboo.triggered.by}, which sets to "manually", "scheduled", "child".
Please advise.
Jason Monsorno
June 30, 2014
${bamboo.ManualBuildTriggerReason.userName}
It's only populated on manual builds but can be used as a flag in a script or something.
https://confluence.atlassian.com/display/BAMBOO/Bamboo+variables
Timothy
June 30, 2014
e
All right, if it's not a variable, then how can I know if the build was triggered manually?
rsperafico
July 1, 2014
Thank you for your question.
You could use the follwing REST API call:
# URI result/PROJECTKEY-PLANKEY
# (where PROJECTKEY-PLANKEY is the key of the desired build plan of a project, e.g. MYPROJ1-MYPLAN1)
http://<bamboo-baseURL>/rest/api/latest/result/MYPROJ1-MYPLAN1?expand=results.result.buildReason
Please, refer to Bamboo REST Resources for further information.
In the XML response, please search for the <buildReason/> tag. You might find the follwing:
&lt;!-- Initial build --&gt;
&lt;buildReason&gt;First build for this plan&lt;/buildReason&gt;
&lt;!-- Manual build --&gt;
&lt;buildReason&gt;
Manual run by &lt;a href="http://BAMBOO-BASEURL/browse/user/admin"&gt;Administrator&lt;/a&gt;
&lt;!-- WebHooks --&gt;
&lt;buildReason&gt;
Changes by &lt;a href="http://BAMBOO-BASEURL/browse/user/admin"&gt;Administrator&lt;/a&gt;
&lt;!-- Scheduled --&gt;
&lt;buildReason&gt;Scheduled&lt;/buildReason&gt;
&lt;!-- Dependency (Child of) --&gt;
&lt;buildReason&gt;
Child of &lt;a href="http://BAMBOO-BASEURL/browse/PROJECTKEY-PLANKEY-BUILDNUMBER"&gt;PROJECTKEY-PLANKEY-BUILDNUMBER&lt;/a&gt;
Rafael
e
Thanks a lot!
